hi guys i'm having a bit of a problem trying to figure out how to represent binary numbers up to 99 in 2 seven segments.
i have my decoder code
library ieee;
use ieee.std_logic_1164.all;
entity Decodificador is
port(
bcd: in std_logic_vector(3 downto 0);
led: out std_logic_vector(6 downto 0)
end Decodificador;
architecture rtl of Decodificador is
begin
process (bcd)
begin
case bcd is
when "0000" => LED <= "1111110";
when "0001" => LED <= "1100000";
when "0010" => LED <= "1011011";
when "0011" => LED <= "1110011";
when "0100" => LED <= "1100101";
when "0101" => LED <= "0110111";
when "0110" => LED <= "0111111";
when "0111" => LED <= "1100010";
when "1000" => LED <= "1111111";
when "1001" => LED <= "1110111";
when others => LED <= "0000000";
end case;
end process;
end rtl;
still it will get up to 9, is there any form to represent the numbers up to 99 without having to declare 99 cases? thank you.
Yes, use your grey cells, you are halfway there : divide and conquer
A tip: think of re-use of module/code- Mark as New
I think you first have to convert a binary natural number into BCD and then instance two times decodificador, one for the units digit and one for the tens.
Remember that 33 in decimal needs 8 bit in BCD (0011 0011) so your convertion module is charge to generate BCD code for units and BCD code for tens. for example: process(...) ....... if(bin>=10 and bin<20) then bcd_tens<="0001" ........ for the units i think you should be able to drive the related decodificator with (bin mod 10) that should be the BCD units by itself.....- Mark as New
thank you memes for your help, as you said had to convert it to bcd, now i made it, thank you guys
