16604 Discussions
AD Converter and SOPC Builder
I have one question about the AD Converter.How can I implement the AD Converter in the Nios 2 System at the SOPC Builder.I dont know what component i must use. I´m new in programming a Nios 2 System.
I am using the DE0-Nano Board.
thx for helping me
There is no such component for this task. Create Your own. You'll find templates in SOPC.
P.S. I'd suggest to use Qsys.
Thank you for your answer. I will try to create my own component.
But for any help or tips to create this component I´m very thankful.
Read manual. Use templates. Very easy to do :)
So I read the maual und try to use templates.Maybe it is easy but I don´t get it.I know what I want to do but I have at the Moment no Idea how I can. Is there perhaps an manuel like this for the SD-Ram somewhere?
https://instruct1.cit.cornell.edu/courses/ece576/de2/tut_de2_sdram_verilog.pdf
The last part of my project is to implement the ADC.
I think I must use an Avalon MM Slave for this but I am not sure.
Then I need an Chip Select output for the ADC and one Input for the Data.
Perhaps you can give me some Tips or can told me if an Avalon MM Slave the right way to do this.
thx
I would use Avalon-ST. But it's just my opinion.
thx, maybe you can give me some more informations??
any other suggestions ???
Again: read the docu!
Hi, it is not like I want you write the code.
I read the docu, the manual of the SOPC Builder,do a Online Class of the SOPC Builder ans other pdfs.
But in the following pdf
http://www.altera.com/literature/ug/ug_embedded_ip.pdf
under Point 8 it´s written when you have a SPI Connection you must/can use the Avalon MM Interface.On the DE0-Nano there is an ADC128S022 with a SPI Interface.
Iam confused what I must or can use because its new for me and I don´t want to go the wrong way.
I know how a SPI Connection works but I dont know how I can implement in an Softcore Nios 2 Processor at the SOPC Builder.
Have a nice weekend.
Wow, I feel your pain! I really hate "RTFM" replies when I have spent weeks trying to grind my way through hundreds of pages only to find that I went down the wrong path or I just can't understand what it is trying to tell me. I too am trying to implement the A/D on the Terasic DE0 NANO. I am even less familiar than you with how to do much of anything at this point. Did you ever find any step by step tutorial or doc.
no I never found an manual like this. I took the code out of the Demo-ACD an tried to improve the code.
It work but not very well. It works very slow but it worked.
Good luck .... and nice weekend
