17186 Discussions
ADC Toolkit: No associated hardware detected
paulw7
I know my board is connected, I know it has being programmed and it is using the ADC with 'JTAG to Avalon Bridge'.... Yet when I run System Console, ADC Toolkit gives me 'No associated hardware detected'
My Quartus version is 20.1.1 Build 720
Any suggestions as to how I get System Console to detect my ADC?
paulw7
I'll add some more info, I was following: https://www.youtube.com/watch?v=0oO1RFa-4Xk
There were a couple of differences along the way, like instead of  Qsys, I'm using Platform Designer and instead of 'Altera Modular ADC Core' it's named 'Modular ADC Core Intel...'. So obviously there have been changes since the tutorial.
Another thing to add, when I load up System Console, I get some messages and there are some red crosses and I don't know what they mean, see image.
Can anyone help with this?
paulw7
JonWay_C_Intel
Hi there, which quartus version are you using? One thing you can do is to revert back to an older Quartus version and see if that works? If it doesnt, then probably it has nothing to do with the version but rather the design itself.
For "No associated hardware detected", try closing the System Console first --> Goto Programmer -->  program the sof into the device --> Run System Console.
JonWay_C_Intel
You can also use this design: https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/max-10-adc-with-threshold-violation-detection/
This is the same implementation as the youtube how to video with additional threshold violation detection.
As a sanity check, download Quartus programmer v16.0, and use the system console to run the design. Make sure that it works.
Then you can try the same design with the newer Quartus version you have installed.
This way, you can rule out if this is a Quartus version issue or design issue.
paulw7
I opened the design you gave me the link to, and it compiles ok. However, my pin assignments are different, so I move the clock and reset to the pins assigned on my board and I try to compile. It fails with this:
Error (170084): Can't route signal "ADC2_PLL:pll|ADC2_PLL_altpll_5q22:sd1|wire_pll7_clk[0]" to atom "ADC2_ADC:adc|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance"
My version is 20.1.1 Build 720 SJ Lite Edition
JonWay_C_Intel
I think you will have to either Upgrade the IP or rebuild (instantiate the newer IP to replace the old one). Then try compiling again.
JonWay_C_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Pranav_pawar
Hi paulw7,
were you able to solve your issue? I am also getting the same kind of error. ADC toolkit doesn't show a launch option and also there are red crosses on devices and connections folder very similar to the image you shared.
I am using 18.1 version, Quartus is able to detect USB Blaster II.
