17249 Discussions
ADPLL using Verilog? Not working!
Guys I am trying to implement ADPLL in verilog using Quartus-II so I can synthesis my model to an FPGA.
on the internet (http://www-unix.ecs.umass.edu/%7edjasinsk/adpll.html) I have found this code that implements an ADPLL designed by R.E.Best on 1999. I tried to simulate this code to test it but it is not working. Compliation OK but no simulation results. Only CK toogles but all other signals are at zero state.
Please help me figure this out. If this code doesnt work out I think I wont try to write my own code for a different ADPLL!
Thank you.
module pll (u1, u2, fc, reset); parameter M = 5; //5 3 parameter N = 4; //4 2 parameter NF = 0; //0 1 input u1, fc, reset; output u2; wire FF1_in, FF3_in, MF_in, Start, CK, reset, Reset; wire Modulus_Control; reg u1_star, Ud, Load; wire u2, div_out; reg u2_prime; reg N_Uf; reg feedback_divider; //*****PULSE FORMING CIRCUIT******// inverter nt3(FF1_in, u1); always @(negedge u1 or negedge reset) begin if(!reset) u1_star <= 0; else u1_star <= !u1_star; end assign CK = u1 && u1_star; assign MF_in = !u1_star; mf mf1(.out (Start), .in (MF_in) ); //*****END PULSE FORMING CIRCUIT****// jk jk1(.Q (FF3_in), .J (Start), .K (u2_prime), .reset (reset), .fc (fc) ); //jk jk1(.Q (FF3_in), .J (Start), .K (u2) ); always@(u2) u2_prime <= u2; /* always@(posedge u2 or negedge reset) begin if(!reset) begin u2_prime <= 0; feedback_divider <= 0; end else begin feedback_divider <= feedback_divider + 1; if(&feedback_divider) u2_prime <= !u2_prime; else u2_prime <= u2_prime; end end */ //*****DIGITALLY CONTROLLED OSCILLATOR****// mcounter# (M) mc1(.u2 (u2), .div_out (div_out), .Reset (Reset), .reset (reset) ); ndivider# (N) nd1(.div_out (div_out), .Load (Load), .fc (fc), .Modulus_Control (Modulus_Control), .reset (reset) ); always @(posedge fc) Load = div_out || Start; assign Reset = Start; //*****END DCO*****// //***PHASE DETECTOR*****// always@(posedge u1_star or negedge reset) begin if(!reset) Ud <= 0; else Ud <= FF3_in; end //***END PHASE DETECTOR***// //***LOOP FILTER***// always@(posedge CK or negedge reset) begin if(!reset) N_Uf <= 6'b010000; else if(Ud==0) N_Uf <= N_Uf+1; else N_Uf <= N_Uf-1; end assign Modulus_Control = N_Uf; //***END LOOP FILTER***// endmodule /////////////////////// module mcounter(u2, div_out, Reset, reset); parameter M = 2; input div_out, Reset, reset; output u2; reg value; reg u2; always@(posedge Reset or posedge div_out or negedge reset) begin if(!reset) begin value <= 0; u2 <= 0; end else if(Reset) begin value <= 0; u2 <= 0; end else begin value <= value + 1; //if (value==5'b11111) u2 <= !u2; if (&value==1) u2 <= !u2; else u2 <= u2; end end endmodule module ndivider(div_out, Load, fc, Modulus_Control, reset); parameter N = 2; input Load, fc, reset; input Modulus_Control; reg value; reg div_out_pre; output div_out; //always@(posedge Load or posedge fc or negedge reset) always@(posedge fc or negedge reset) begin if(!reset) begin value <= 0; div_out_pre <= 0; end else if(Load) begin value <= Modulus_Control; div_out_pre <= 0; end else if(value != 0) begin value <= value - 1; div_out_pre <= 0; end else div_out_pre <= 1; end assign div_out = div_out_pre; endmodule module jk (Q, J, K, reset, fc); input J, K, reset, fc; output Q; reg Q; reg Q1, Q2; always@(posedge J or negedge reset) begin if (!reset) Q1 <= 0; else if(K==1) Q1 <= !Q; else Q1 <= 1; end always@(posedge K or negedge reset) begin if (!reset) Q2 <= 0; else if(J==1) Q2 <= !Q; else Q2 <= 0; end always@(Q1 or Q2) begin Q <= Q1 || Q2; end /* always@(posedge J or posedge K) begin if((J==0)&&(K==0)) Q <= Q; else if((J==0)&&(K==1)) Q <= 0; else if((J==1)&&(K==0)) Q <= 1; else Q <= !Q; end */ endmodule module mf (out, in); input in; output out; wire flag, flag2; reg out; inverter nt4 (flag, in); inverter nt5 (flag2, flag); always@(in or flag2) begin if(!in) out <= 0; else out <= in ^ flag2; end endmodule module inverter (out, in); // inverter output out; input in; reg out; always @(in) begin# 1 out <= !in; //out <= !in; end endmodule
Before looking though the code I thought I'd check the simple stuff first :)
What are you using for stimulus? Have you written a testbench? What drives the clock and reset inputs? (Looks like an active low reset)
Are you simulating on Quartus or modelsim?
I see some dubious constructs, e. g. CK is a gated clock that probably has glitches and must cause timing violations. The code has to be reworked to get a proper synchronous design. Other issues may exist, too.
--- Quote Start ---
--- Quote End ---
Im using QuartusII.
If u check the link in the first post wer I got the code from, it has figures for the block diagram and the supposed simulation results.
--- Quote Start ---
--- Quote End ---
Can u elaborate more please?
Why are you using Verilog and not the PLL Megafunction of QuartusII?
This a classical example of a gated clock, it's used in the design to clock other modules
--- Quote Start ---
begin
end
--- Quote End ---
Please consult Quartus handbook or FPGA/HDL text books why it's a possible issue. I guess, you can see in timing simulation, if you look sharp.
Generally, I see that there are possible reasons to use a DPLL (digital PLL) respectively ADPLL (all digital PLL) in a design. Apart from practical purpose in some design, it may be used for educational purposes, e.g. to better understand the stuff presented in Best's book.
Please consider, that I didn't yet try to use the code. I didn't say, that the gated clock issue is a reason, why the design doesn't work. There may be a much more basic problem with the points, vernmid mentioned. But it would be a problem, when using the code in a real design.
--- Quote Start ---
--- Quote End ---
I need to synthesis my code on FPGA to test, then synthesized it an actual chip using CAD tools.. thats why..
--- Quote Start ---
--- Quote End ---
Thanx for the input.
Any idea of other methods for clock data recovery other than ADPLL? (verilog applicable methods)..?
DPLL are used e. g. in USB controller cores, they clearly have an application field. On the other hand, cause a DPLL has a jitter of one input clock period, it isn't usable for a lot of applications and can't replace an analog PLL so far.
Cause I don't know your application, I can't rate if a DPLL is a feasible solution.
The feasibility of an alternative method depends on the maximum sampling frequency that you can apply to the input data. The more you oversample the input, the more you will be accurate in clock and data recovery. But certainly, as FvM says, it is difficult to suggest you an appropriate solution without knowing well your application.
