Hi!
I'm using Quartus Standard Prime 23.1.1 to upgrade a NiosII C10LP design to NiosV and I'm having trouble with the BSP / Linker.
From the description of the hal.linker.enable_exception_stack option in settings.bsp:
Enables use of a separate exception stack. If true, defines the macro ALT_EXCEPTION_STACK in linker.h, adds a memory region called exception_stack to linker.x, and provides the symbols __alt_exception_stack_pointer and __alt_exception_stack_limit in linker.x.
So, in my linker.h file I do see the macro ALT_EXCEPTION_STACK defined; however, in my linker.x there is no memory region called exception_stack.
Is there something else I need to do to make sure this memory region is generated?
Hi
Sorry for the long delay in getting back to you as there is some backlog on our end.
Let me investigate on this matter and feedback to you
Kian
Hi
Apologies for the delay in getting back as was tied up with issue backlog, may I know whether the issue been resolved on your end?
For the linker exception , I saw there is some restriction mentioned at NiosV guide
Just make sure to adhere to the restriction condition mentioned in the link above. Is there an issue or error that you're facing when migrating to Nios V design?
Kian
Hi
I've set this thread to post community support but if you require further support, please do login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support only. The community users will be able to help you on your follow-up questions.
Kian
