ALTLVDS in SOPC
Colaborador Distinguido II
1.170 Vistas
I am using Quartus II 8.0 for programming a Cyclone III device. I have a 2 LVS clocks (fclk and lclk) and a channel (12 bit) LVDS input that I wish to deserialize. I use 2 channels and factor 6.
In SOPC I create a ALTLVDS component ...
In SOPC: Tools -> IP MegaStore...
/ Create a new custom megafunction variation
/ Cyclone III device,VHDL, ALTLVDS:
LVDS_RECEIVER, 2 channels;
deserialization factor = 6;
use external PLL = ON;
enable bitslip control = OFF;
generate netlist = OFF;
and the all options from last page = ON; and finish
Later, in SOPC:
Create new component ->
in hdl menu, I load only the .vhdl file created
in signals menu:
rx_inclock = interface clock_sink (Clock Input);
signal type = clk;
rx_in = interface avalon_slave0;
signal type = writebyteenable;
rx_out = interface avalon_slave0;
signal type = readdata;
in interfaces menu:
All default and associated clock = clock_sink
and finish...
My problem is: I add the ALTLVDS component in my SOPC project, but nothing happens in the main project in quartus ( after to compile ), in pin planner any pin from ALTLVDS componet appears (rx_in, rx_out...) and when I try to write some thing about the component in the main file (myproject.v) , the quartus doesn't recognize it...
Please, help me....
0 kudos
1 Responder
478 Vistas
up
somebody can help me ?
Responder
