About VGA Output
I am working for the first time with FPGA (cyclone v soc) and i am trying to get a output from VGA Port on the monitor. I have set the resolution for 1024x768 and PLL input frequency as 50MHz and output frequency as 65MHz as required for the resolution.But as soon as i program the board the monitor is going to sleep mode. I am attaching the code which i used for this. Can you please tell me what may be the problem. When I checked in RTL Simulation PLL is not generating any clock output.
Thank you in advance.
Code:
----Main code
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY VGA IS
PORT(
CLOCK_24: IN STD_LOGIC;
SYS_rst : IN STD_LOGIC;
VGA_HS, VGA_VS: OUT STD_LOGIC;
VGA_R, VGA_G, VGA_B: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
VGA_CLK_65MHZ : OUT STD_LOGIC
END VGA;
ARCHITECTURE MAIN OF VGA IS
SIGNAL VGACLK, RESET, lock : STD_LOGIC :='0';
signal SIGNAL_135MHZ : STD_LOGIC:= '0';
COMPONENT SYNC IS
PORT
CLK : IN STD_LOGIC;
HSYNC, VSYNC : out std_logic;
R, G, B : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
component unsaved is -- PLL Component
port (
pll_0_locked_export : out std_logic; -- pll_0_locked.export
pll_0_outclk0_clk : out std_logic; -- clk
pll_0_refclk_clk : in std_logic := '0'; -- clk
pll_0_reset_reset : in std_logic := '0' -- reset
end component unsaved;
BEGIN
inst_pll : UNSAVED port map
pll_0_refclk_clk => clock_24,
pll_0_reset_reset => SYS_rst,
pll_0_outclk0_clk => VGACLK, ---CLOCK 65 MHZ
--outclk_1 => SIGNAL_135MHZ, --- CLOCK 135 MHZ
pll_0_locked_export => lock
INST_SYNC : SYNC PORT MAP
CLK => VGACLK,
HSYNC => VGA_HS,
VSYNC => VGA_VS,
R => VGA_R,
G => VGA_G,
B => VGA_B
VGA_CLK_65MHZ <= VGACLK;
END MAIN;
---Sub Program
LIBRARY IEEE;
ENTITY SYNC IS
PORT(
CLK : IN STD_LOGIC;
END SYNC;
ARCHITECTURE MAIN OF SYNC IS
SIGNAL HPOS: INTEGER RANGE 0 TO 1344:=0;
SIGNAL VPOS: INTEGER RANGE 0 TO 806:=0;
BEGIN
PROCESS(CLK,HPOS,VPOS)
BEGIN
IF(CLK' EVENT AND CLK='1') THEN
IF (HPOS = 832 OR VPOS = 422) THEN
R <= (OTHERS => '1');
G <= (OTHERS => '1');
B <= (OTHERS => '1');
ELSE
R <= (OTHERS => '0');
G <= (OTHERS => '0');
B <= (OTHERS => '0');
END IF;
IF(HPOS<1344) THEN
HPOS <= HPOS+1;
ELSE
HPOS <=0;
END IF;
IF (VPOS<806)THEN
VPOS <= VPOS+1;
ELSE
VPOS <=0;
END IF;
END IF;
IF (HPOS > 24 AND HPOS < 160)THEN
HSYNC <= '0';
ELSE
HSYNC <= '1';
END IF;
IF (VPOS > 3 AND VPOS < 9) THEN
VSYNC <= '0';
ELSE
VSYNC <= '1';
END IF;
IF ((HPOS> 0 AND HPOS< 320) OR (VPOS>0 AND VPOS< 38)) THEN
END IF;
END PROCESS;
END MAIN;
PLL reset is usually an active high signal. Please check that. It could be the problem
Bhavya K
thank you so much for your reply. i Tried with that but same problem exists. Can you please check the program once..? is there any problem with code...?
waiting for your reply
regards,
Prashanth
I don't quite understand the sync code. The resolution is XGA(1024x768) but your HPOS and VPOS maximum values are 800 and 525 which is not proper.
hello,
I am really sorry i had done the programming for 640x480 and 1024x768 resolutions. had forgot to change the values. Now i have changed the values. am really sorry for this.
Even for the values of resolution 1024x768 im not getting any clock output
regards
Prashanth
Clock output is from the PLL. So where are you checking this clock? Are you probing or checking in simulation? The only reason should be that either the input clock or reset has a problem. Im not seeing any other reason for not getting the clock output
hello,
yes. i am checking that clock in Modelsim Altera starter edition 10.4b version. I have written the test bench program to check the output in modelsim.
test bench code:
LIBRARY IEEE;
ENTITY VGA_TB IS
END ENTITY VGA_TB;
ARCHITECTURE BEHAVIOUR OF VGA_TB IS
SIGNAL CLOCK_24: STD_LOGIC:= '0';
SIGNAL SYS_rst : STD_LOGIC:= '1';
SIGNAL VGA_HS, VGA_VS: STD_LOGIC:= '0';
SIGNAL VGA_R, VGA_G, VGA_B: STD_LOGIC_VECTOR(7 DOWNTO 0):= (OTHERS => '0');
SIGNAL VGA_CLK_65MHZ : STD_LOGIC:= '0';
COMPONENT VGA IS
PORT (
END COMPONENT;
BEGIN
INST_VGA : VGA
PORT MAP (
CLOCK_24 => CLOCK_24,
VGA_HS => VGA_HS,
VGA_VS => VGA_VS,
VGA_R => VGA_R,
VGA_G => VGA_G,
VGA_B => VGA_B,
VGA_CLK_65MHZ => VGA_CLK_65MHZ);
CLOCK_PROC : PROCESS
BEGIN
CLOCK_24 <= '0';
WAIT FOR 10 NS;
CLOCK_24 <= '1';
WAIT FOR 10 NS;
END PROCESS;
SYS_rst <= '0', '1' AFTER 100 NS;
END;
Change the reset generation to
SYS_rst <= '1', '0' AFTER 100 NS;
Please attach simulation waveform snapshot if this does not work
i did that change but I did not get the answer. I have attached the snapshot of output here. now i am thinking whether i am doing proper procedure for simulation or not.
Please help me doing this.
Thank you
Thank you so much for helping me. But i could not follow the instructions given there. If you don't mind can you please check my project file which i am attaching here...?
regards,
Prashanth
This is the output im getting in model sim simulation. But when i program the board the monitor is going to power saving mode. What may be the problem..?
Waiting for help,
Thank you
regards,
Prashanth
I'm sorry but the waveform is not visible. Is the 65MHz clock output fine now?
yeah it looks fine.. but at one point it remains on for one full cycle. I will attach the pulse waveform with zoom. Please check it.
According to your logic, the RGB data remains zero at all times, except at this condition
So what are you expecting on the display? And is there any decoder on the output path to be configured?
hi,
I want to draw one vertical and one horizontal line at the middle of the screen.
decoder on the output path..?? no i guess
Then it looks fine. If its fine in simulation then it should be working on board
may i ask you what do u mean by configuring the decoder on the output path....??
i dont know why monitor is going to power saving mode. Its Dell LCD monitor with maximum resolution of 1366x768. Should i try with old CRT monitor..?
pnayak15 -
What is driving the monitor? Is the FPGA output going to a DVI or HDMI transmitter? If so, what is driving the DE input to the transmitter?
I can't see your simulation waveforms because your JPEGs are too small, but from your VHDL code it looks like the PLL is held in reset. Are you sure your clocking is ok? Can you probe your clock on the board to verify?
hii rsefton,
VGA clock output is driving the monitor.
Is the PLL Held in RESET.?? I am not sure whether the output is proper but im getting continuous vga clock output pulses.
I can you mail you the simulation waveform if it is fine. Please drop a empty mail at prashanthnayak16@gmail.com
I really need to get it sorted soon
Thank you
Hi pnayak15 -
It's not possible to drive a monitor directly with 27 2.5V signals (VGA_CLK, VGA_VS, VGA_HS, VGA_R[7:0], VGA_G[7:0], VGA_B[7:0]). There must be an encoder/transmitter IC between the FPGA and the monitor (I assume DVI or HDMI). These transmitter ICs typically have a DE (data enable) input that must be driven. If you don't drive that signal then you won't get a valid signal to the monitor.
What is between the FPGA and monitor? Include everything, including (transmitter, connector, cable, etc). And what model of monitor are you driving?
