17253 Discussions
About timing constraints of ‘in2out’ timing path
Q: About timing constraints of‘in2out’ timing path
My design is as follows:
file:///C:/Users/dell/AppData/Local/Temp/msohtml1/01/clip_image002.gif
In my design, there are three ports: clk(system clock), ina(input port), outb(output port). My constraints are as follows:
create_clock -period 10 -name my_clk [get_ports clk]
set_input_delay -max 3 -clock my_clk [get_ports ina]
set_ouput_delay -max 3 -clock my_clk [get_ports outa]
set_max_delay 2 -from ina -to outb
When Quartus tools analysis the 3rd timing path, the required time calculated as follows:
3(input_delay) + 3(output_delay) + 2(max_delay) + tdelay(com logic delay) <10(clock cycle)
But I want to constraint the delay less than 2ns from ‘ina’ to ‘outb’, I don’t know how to constraint the timing path, could you please give me some advise for this case?
wuyu
--- Quote Start ---
wuyu
--- Quote End ---
May I ask what is the thinking here?
you have an input (ina) going direct to output (outb) through some comb. logic that receives a registered version of ina(call it ina_r).
So ina_r will get sampled at clock edge running every 10 ns yet you want ina to outb < 2ns???
--- Quote Start ---
--- Quote End ---
You're already constraining that.
You're giving TimeQuest two sets of constraints
- tdelay < 2.0 from the set_max_delay constraint.
- 3 + tdelay + 3 < 10, from the set_input_delay and set_output_delay constraints.
That said, achieving a 2.0 ns delay is going to be hard, if not impossible.
I'm sorry for the description fault, the tool calculate the required time is as follows:
2ns(max_delay) - 3ns(output_delay) = -1ns;
And the arrived time is as follows:
3ns(input_delay) + tDELAY;
So tools think the constraints should be:
3ns(input_delay) + tDELAY < -1ns => tDELAY <-4ns;
But my thinking is that I want to constraint the max delay time is 2ns from ina to oub (tDELAY < 2ns), so, for that, I need to constraint the max_delay is 8ns;
It is right?
--- Quote Start ---
--- Quote End ---
It is right?
--- Quote Start ---
It is right?
--- Quote End ---
--- Quote Start ---
It is right?
--- Quote End ---
I don't see how you found out what the tool is thinking.
set_input_delay has nothing to do with tdelay path. It is meant for register path only, so is set_output_delay. And in both cases it has nothing to do with concept of pure delay.
set_input_delay is information to the tool about data/clock offset arriving at pins. set_output_delay is information to the tool about allowed range of data/clock offset ejected at output pin.
The path of tdelay is comb. from pin to pin and I suppose it will be dealt with independant of register path. Whether you get it or not is up to your luck but still I don't understand the merits of your approach from basic design perspective. May be you tell us what is the purpose of your constraints...
Thanks for your help. And this case is only my little example from my all design.
I try to clear this question through Design Compiler in Synopsys, and I have found
the way to solve my constraints question. The setup calculate is as follows:
Required time: Value(max_delay) - Value(output_delay=3ns);
Arrived time: Value(input_delay=3ns) + tdelay;
Setup ensure: Arrived time <= Required time
So, if I want to constraint the tdelay max 2ns, the result is that we should constraint the max_delay 8ns.
set_max_delay 8 -from ina -to outb
No matter at all, thanks. Hope we could commucation more latter.
--- Quote Start ---
--- Quote End ---
