16210 Discussions
Add files to Quartus thanks to a list file
Busy
Until now, when I want to add files to my project, I modify .QSF file by adding a line:
set_global_assignment -name IP_FILE filename1.ip set_global_assignment -name IP_FILE filename2.ip
Now I would like to include all the files into one text file and add this (only) file into the project.
For example (it should be easier to understand):
I've got two files: filename1.ip and filename2.ip.
Instead of having two lines into the .QSF:
I'd like to add only one line (in the .QSF); such as
set_global_assignment -name xxx_FILE filelist.txt
with filelist.txt containing the two path to the IP:
 If I use '.QIP' extension and 'set_global_assignment -name QIP_FILE filelist.qip', Quartus complains 'Critical Warning(125091): Tcl error: ERROR: Option "-qip" for "IP_FILE" assignment is illegal. Specify a legal option or remove the option.'
If I use '.IP' extension and 'set_global_assignment -name IP_FILE filelist.ip', Quartus complains 'The synthesis RTL for ../src/filelist.ip has not been generated'.
I know that I can modify the .QSF (using SED or AWK) but I'd like something simpler (main objective is to automatically list all IP files present into a directory (with a 'ls' command) and put this list in the filelist.txt file).
Many thanks!
AnandRaj_S_Intel
Try adding ip files in tcl and include it in qsf.
set_global_assignment -name SOURCE_TCL_SCRIPT_FILE filename.tcl
or try
source filelist.txt
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
AnandRaj_S_Intel
or try
source filelist.txt
Anand
Busy
Perfect!
I use 'source filelist.qsf'
Thank you!
