SignalTap allows more than one clock to be added to the clock list of an instance.
What will be the effect of adding more than one clock ?
(Virus scan in progress ...)
You could only add one clock in the Signal Configuration to sample the data. If you need for another sampling clock, this can be done through creating another SignalTap instance , ie In Instance>Right click "create instance"
Topic Options
