17255 Discussions
Agilex 7 devices design example programming failed.
Eric_100
OS: Win 11 Pro
Quartus: Prime Pro 23.4.0 Build 79
I downloaded a sample code for Agilex 7 devices from https://www.intel.com.tw/content/www/tw/zh/design-example/787040/agilex-7-fpga-hello-world-on-the-nios-v-m-processor-design-example.html
But it always shows an error message about WAITREQUEST_ALLOWANCE as below:
altera_merlin_slave_translator_inst: no such parameter: WAITREQUEST_ALLOWANCE
Thx.,
Eric
NurAiman_M_Intel
Hi Eric,
I have tested the design example from my end and it is successful.
  1. Please used Quartus Pro version 24.1 as suggested for the design example.
  2. Upgrade you IP tool. I saw from your photo there is a pop up suggested to upgrade IP.
  3. Run the design example again.
Aiman
NurAiman_M_Intel
-Can you share the screenshot of the error message?
-Has the design ever work before?
-What is the Quartus version that you used?
-Make sure to select the correct device (AGFB014R24B2E2V)
Aiman
Eric_100
Hi
Here are screenshots of the error message.
How can I fix this error message?
I am using Quartus Pro Edition and NIOS V for the first time.
I have used Quartus Prime Lite Edition and NIOS II before and did not have this problem.
My Quartus version is Prime Pro 23.4.0 Build 79 11/22/2023 SC Pro Edition.
The Device ID is correct.
Thx.,
Eric
Eric_100
I have had a go at building the same system with Quartus Prime Lite and it can be successfully compiled.
Why does compilation always fail when using Quartus Prime Lite?
Eric
Eric_100
Why does compilation always fail when using Quartus Prime Pro?
Eric
NurAiman_M_Intel
Hi Eric,
Aiman
Eric_100
Hi Aiman,
I run the design example on Quartus Pro version 24.1.
I have updated all IP tools.
I still get the same error message and other error messages.
Or is there something wrong with my Quartus settings?
Quartus Version: Quartus Pro version 24.1.0.115
Eric
Eric_100
Hi Aiman,
After removing and reinstalling all Quartus related tools from my PC, it can now be compiled successfully.
Thanks for your help.
Eric
NurAiman_M_Intel
Hi Eric,
Glad to hear that! Thanks for the update.
Aiman
