Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Altera DE-1: "Error: Can't recognize silicone ID for device 1"
Dear fellow Forum Users,
I am struggling to flash a POF to my brand new DE-1. I can connect to the device via the control panel app, I can flash binaries to the memory from there, I can flash a SOF to the DE-1 via Quartus in JTAG mode, but whenever I try to switch to "Active Serial Programming" mode, and flash a POF, I get the message "Error: Can't recognize silicon ID for device 1".
I have followed the various threads on this topic, and have tried the solutions described in there, without success. What I have done by now:
- Try different USB cables and USB ports (both directly on the PCs motherboard, as well as via an active USB hub)
- Try different versions of Quartus (13 and 16.1), both with the same results
- Try different OS (Win 10 64bit, Win 7 32 bit via Virtualbox, native Linux Quartus on Ubuntu 16.04), all with the same results
The device is also autodetected when using the corresponding button in Quartus' programmer popup, however, I am greeted with the following popup when using it:
"Encounter devices with shared JTAG header for device 1. Please select your device: [] EP2C15 [] EP2C20"
(see screenshot at http://www.kersch.at/quartus.png
I have not connected another FPGA or JTAG enabled device to this PC.
Any suggestions on how to proceed? Thanks for your support!
Martin
