When compiling a design ,I encouter an error : Out of memory in module quartus_map.exe(2127 megabytes used). Does it mean the memory of my computer is not enough for quartus to fulfill the compilation? Thanks !Link Copied
Yes your design is too large for the amount of RAM you have.
On 32-bit windows, I think processes are limited to about 2GB of memory even if the computer has 4GB. The only way to use more memory is therefore to get 64-bit windows.- Mark as New
According to Quartus readme.txt, designs for all Altera FPGA devices, except for Stratix IV can be handled with 4 GB memory and 32-Bit Windows.
If you have 32-bit Windows and 3 GB of physical RAM, you can try the /3GB switch. See http://www.altera.com/support/kdb/solutions/rd11172005_572.html?gsa_pos=1&wt.oss_r=1&wt.oss=3gb. Lots of people have trouble getting that to work though (Windows issue, not a Quartus issue).
