17256 Discussions
Analysis & Synthesis Error(13224): Verilog HDL or VHDL error "..:" index -8 is out of range [15:0]..
Ranesh
I have following error while Analysis & Synthesis using Qyartus 21.2 and 22.2:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(143): index -8 is out of range [15:0] for 's_in_data'
I have added my project (vector_capture_21_2). The project can be found in vector_capture_21_2\quartus_proj and source files can be found in vector_capture_21_2\src
According to my code and parameter assignments, the index cannot be -8, but I am not clear how the tool see -8 as an index.
Can someone help me to overcome this issue?
Thank you,
Ranesh
ShengN_Intel
Hi @Ranesh ,
The reason for the error is the value of parameter W_MODULE_DATA (256) in submodule vector_capture.sv being overridden by the value of parameter W_MODULE_DATA (16) in top-module vector_capture_synth_top.sv.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Ranesh
Hi Sheng,
Thank you for your answer.
What you are saying is correct, but that cannot be the reason for this error message.
From lines 26 and 27 of vector_capture_synth.sv
26: parameter W_MODULE_DATA = 16; // Supported data widths (8 bits to 256 bits) power of 2 (2^3 to 2^8)
27: parameter W_MODULE_DESC = 204; // less than or equal to 256
From lines 66 to 70 of vector_capture.sv are:
66: localparam c_DESCBYTEALIGNBITS = ((W_MODULE_DESC % > 0) ? (8 - (W_MODULE_DESC % 8)) : 3'b0;
                            c_DESCBYTEALIGNBITS = ((204 % > 0) ? (8 - (204 % 8)) : 3'b0
                            c_DESCBYTEALIGNBITS = 4
67: logic [((W_MODULE_DESC + c_DESCBYTEALIGNBITS) - 1):0] s_in_desc; // Configuration bus from feeder module
        logic [((204 + 4) -1):0] s_in_des
        logic [207:0] s_in_des
68: localparam c_IN_DESC_BYTE_CNT = ((W_MODULE_DESC + c_DESCBYTEALIGNBITS)/8);
                              c_IN_DESC_BYTE_CNT = ((204 + 4)/8)
                              c_IN_DESC_BYTE_CNT = ((208)/8)
                              c_IN_DESC_BYTE_CNT = 26
69: localparam c_IN_DATA_BYTE_CNT = (W_MODULE_DATA/8);
                               c_IN_DATA_BYTE_CNT = (16/8)
                               c_IN_DATA_BYTE_CNT = 2
70: localparam c_OUT_DATA_BYTE_CNT = (W_MCDMA_DATA/8);
                               c_OUT_DATA_BYTE_CNT = (256/8)
                               c_OUT_DATA_BYTE_CNT = 32
The lines 140 and 144 are in vector_capture.sv are:
140: for (int c = c_IN_DESC_BYTE_CNT; c < c_OUT_DATA_BYTE_CNT; c++)
                 (int c = 26; c < 32; c++)
                c can take only 26, 27, 28, 29, 30 and 31
141: begin
142:    if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty)))
                 (c < (26 + (2 - s_in_empty)))
                 (c < (28 - s_in_empty))
                 if s_in_empty is 0
                   c can take only 26 and 27
                 if s_in_empty is 1
                   c can take only 26
143:         s_output_data[c] <= s_in_data[((W_MODULE_DATA - ((c - c_IN_DESC_BYTE_CNT) * 8)) - 1) -: 8];
                  If c become 26, the line becomes
                      s_output_data[26] <= s_in_data[((16 - ((26 - 26) * 8)) - 1) -: 8]
                      s_output_data[26] <= s_in_data[((16 - ((0) * 8)) - 1) -: 8]
                      s_output_data[26] <= s_in_data[((16 - 0 - 1) -: 8]
                      s_output_data[26] <= s_in_data[15 -: 8]
                      s_output_data[26] <= s_in_data[15 :  8]
                  If c become 27, the line becomes
                      s_output_data[27] <= s_in_data[((16 - ((27 - 26) * 8)) - 1) -: 8]
                      s_output_data[27] <= s_in_data[((16 - ((1) * 8)) - 1) -: 8]
                      s_output_data[27] <= s_in_data[((16 - 8 - 1) -: 8]
                      s_output_data[27] <= s_in_data[7 -: 8]
                      s_output_data[27] <= s_in_data[7 :  0]
144: end
From the above calculations, c cannot take any values that drives the index of s_in_data to be -8.
Ranesh
Ranesh
Hi Sheng,
What you are saying is correct, but it cannot be the cause of this error.
Lines 21, 26 and 27 of vector_capture_synth_top.sv are:
21: parameter     W_MCDMA_DATA  = 256;
Lines 66 to 70 of vector_capture.sv are:
                            c_DESCBYTEALIGNBITS = (4 > 0) ? (8 - 4) : 3'b0
        logic [((204 + 4) - 1):0] s_in_desc;
        logic [207:0] s_in_desc;
Lines 140 to 144 of vector_capture.sv are:
               Within this for loop, c can take only 26, 27, 28, 29, 30 and 31
141: begin
           Note: s_in_empty is a single bit.
           Within this if statement:
               If s_in_empty = 0, (c < (28 - 0)) and c can be either 26 or 27
               If s_in_empty = 1, (c < (28 - 1)) and c can be either 26
        If c takes 26
         s_output_data[26] <= s_in_data[((16 - ((26 - 26) * 8)) - 1) -: 8];
         s_output_data[26] <= s_in_data[((16 - ((0) * 8)) - 1) -: 8];
         s_output_data[26] <= s_in_data[((16 - (0) - 1) -: 8];
         s_output_data[26] <= s_in_data[((16 - 1) -: 8];
         s_output_data[26] <= s_in_data[15 -: 8];
         s_output_data[26] <= s_in_data[15 : 8];
        If c takes 27
         s_output_data[26] <= s_in_data[((16 - ((27 - 26) * 8)) - 1) -: 8];
         s_output_data[26] <= s_in_data[((16 - ((1) * 8)) - 1) -: 8];
         s_output_data[26] <= s_in_data[((16 - (8) - 1) -: 8];
         s_output_data[26] <= s_in_data[((8 - 1) -: 8];
         s_output_data[26] <= s_in_data[7 -: 8];
         s_output_data[26] <= s_in_data[7 : 0];
144: end
From the above calculations, c cannot take any values that drives index of s_in_data to be -8.
Ranesh
Ranesh
Hi Sheng,
141: begin
        If c takes 26
        If c takes 27
144: end
Ranesh
ShengN_Intel
Hi @Ranesh ,
I further create a test case with minimized code.
I'm getting synthesis error Error(13224): Verilog HDL or VHDL error at test.sv(19): index -8 is out of range [15:0] for 's_in_data' as you mentioned before in Quartus Pro v21.2 check image:
I further test with Vivado v2022.1. I'm also getting the similar synthesis error [Synth 8-524] part-select [-1:-8] out of range of prefix 's_in_data' check image:
I further found out that the root cause is at variable s_in_empty in module vector_capture.sv. You can't use logic type s_in_empty in for loop if statement. If change the type of variable s_in_empty from logic to for example parameter, both Quartus and Vivado can successfully synthesis the code check image:
Therefore, I believe this is expected behavior.
Sheng
ShengN_Intel
Hi @Ranesh ,
Let me know if you have any further update or concern.
Sheng
Ranesh
Hi Sheng,
I have noticed that if I eliminate s_in_empty in the if condition, there is no synthesis error. In another segment of my vector_capture.sv I am using an internal counter that is to count number bytes in s_output_data and there is no synthesis error in this line.
I have attached modified vector_capture.sv for your consideration.
Please note that line 142 is commented and 143 is introduced to avoid previous synthesis error.
Also, please note that line 147 to line 153 are introduced with s_outbytecount, but the line 150 if condition is not produce any synthesis error as before.
Ranesh
Ranesh
Hi Sheng,
I forgot to mentioned that s_outbyteconut is also a logic type and used in for loop if statement.
Ranesh
ShengN_Intel
Hi @Ranesh ,
In your updated code, there are differences between the lines 144 and 151.
Line 144:
Line 151:
s_output_data[d] <= s_in_data[((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) -: 8];
For line 151, if change s_outbytecount to c_IN_DESC_BYTE_CNT also produce the error below:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(151): index 136 is out of range [15:0] for 's_in_data'
For line 144, if change c_IN_DESC_BYTE_CNT to s_in_empty and with previous if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty))), there'll be no error produced as well.
So you're comparing two different things. Let me know if you have any further concern.
Sheng
Ranesh
Hi Sheng,
Please don't compare line 144 and 151, they are not causing this error.  If you change line 144 to have
(c - c_IN_DESC_BYTE_CNT) > 2, it will produce negative index for s_in_data and similarly, in line 151, if
(d - s_outbytecount) > 2, it will produce negative index for s_in_data. This is because W_MODULE_DATA = 16.
Please don't change any of these lines.
Please compare lines 142 (commented), 143 with line 150.
If line 142 is used, the compiler produced following error:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(144): index -8 is out of range [15:0] for 's_in_data'
If line 143 used, which does not use s_in_empty in for loop if statement, the compiler does not produced any error
For this error, you have mentioned:
Please note that line 150 is using a logic type s_outbytecount in for loop if statement, which does not cause any synthesis error. This shows that a logic type can be used in for loop if statement.
Thank you.
Ranesh
ShengN_Intel
Hi @Ranesh ,
parameter   W_MCDMA_DATA = 256,
parameter   W_MCDMA_EMPT = $clog2(W_MCDMA_DATA/8),
logic [(W_MCDMA_EMPT - 1):0] s_outbytecount;
Variable s_outbytecount is 5-bit variable. So it should range from 0 to 31 right.
If s_outbytecount is 0 means in line 151 if I change s_outbytecount to number 0, I'm getting the same error as before:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(151): index -8 is out of range [15:0] for 's_in_data'
If I change s_outbytecount to number 31, I'm also getting error:
Error(13224): Verilog HDL or VHDL error at vector_capture.sv(151): index 256 is out of range [15:0] for 's_in_data'
But there's no error if using logic s_outbytecount. Probably you can't use logic type in both for loop if statement and if block.
Btw, if this is a bug with Quartus, I should be able to compile the code with other synthesis tool. But I'm getting the same synthesis error with Vivado so I believe this is not a bug. Let me know if you manage to get it compiled with other synthesis tool.
Sheng
Ranesh
Hi Sheng,
You cannot change s_outbytecount to 0 only in line 151, you have to change s_outbytecount in line 150 to 0 as well, because line 151 is constrained by line 150.. By changing value of s_outbytecount to 0 only in line 151, you are making logical error and regardless of compiler this would lead to an error.
Please do not play with s_outbytecount in line 151. You can notice that s_outbytecount is calculated in line 146 and 153.
If you want to change s_outbytecount to see line 151 behavior, you have to calculate (d - s_outbytecount) value in line 151.
W_MODULE_DATA = 16,
c_OUT_DATA_BYTE_CNT = 32,
c_IN_DATA_BYTE_CNT = 2  and
Line 148 to152:
148: for (int d = 0; d < c_OUT_DATA_BYTE_CNT; d++)
149: begin
150:   if ((d >= s_outbytecount) && (d < (s_outbytecount + c_IN_DATA_BYTE_CNT)))
151:     s_output_data[d] <= s_in_data[((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) -: 8];
152: end
In line 148 d can take 0 to 31
In line 151 d is constrained to be from s_outbytecount to (s_outbytecount + c_IN_DATA_BYTE_CNT) - 1
Since W_MODULE_DATA = 16, ((d - s_outbytecount) * 8)) can take only 0 or 8.
when ((d - s_outbytecount) * 8)) = 0, ((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) = 15
when ((d - s_outbytecount) * 8)) = 8, ((W_MODULE_DATA - ((d - s_outbytecount) * 8))- 1) = 7
So line 151 would not have any errors
In other words, ((d - s_outbytecount) * 8)) cannot be greater than 8 or less than 0.
Please concentrate only on line 142, 143 (these if statements are bound by for loop in line 140)
and 151(this if statement is bound by for loop in line 150).
Ranesh
Ranesh
Hi Sheng,
There was a mistake in last line of my last reply:
The lie
"Please concentrate only on line 142, 143 (these if statements are bound by for loop in line 140)
and 151(this if statement is bound by for loop in line 150)."
is not correct. It should be
"Please concentrate only on line 142, 143 (these if statements are bound by for loop in line 140 and 145)
and 150 (this if statement is bound by for loop in line 148 and 152)."
Thank you.
Ranesh
ShengN_Intel
Hi @Ranesh ,
Let me get proper explanation from expert and get back to you soon.
Ranesh
ShengN_Intel
Just an update. Still pending response from internal expert.
ShengN_Intel
Hi @Ranesh ,
Internal Feedback:
For the expression if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty)))
1. When "s_in_empty" is of type logic, the expression in if condition can't be evaluated at compile time. So all possible indices are generated for "s_in_data".
e.g., for value of c = 18 onwards, index for s_in_data becomes negative.
Let me further check with expert on the second example you provided.
Sheng
Ranesh
Hi Sheng,
Please note that the expression if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty))) is bound by the expression for (int c = c_IN_DESC_BYTE_CNT; c < c_OUT_DATA_BYTE_CNT; c++). This limits c not to be below c_IN_DESC_BYTE_CNT, which is 26. So in the expression s_output_data[c] <= s_in_data[((W_MODULE_DATA - ((c - c_IN_DESC_BYTE_CNT) * 8)) - 1) -: 8], which is bound by the expression that you have mentioned, c can only be 26 or 27, because s_in_empty is single bit signal and c_IN_DATA_BYTE_CNT = 2.
I am re-attaching my explanation in word document for you and the expert
Ranesh
FvM
Hi Ranesh,
I think it would be helpful if you can provide a stripped code example that shows the problem, without all unneeded project stuff and with irrelevant module instantiations commented out.
Frank
Ranesh
Hi Sheng,
I have attached entire folder for you and the expert.
Thank you.
Ranesh
