17049 Discussions
Arria V GX: Couldn't place LVDS outputs.
Hello, everyone.
I'm trying to implement 12 bits LVDS outputs in Arria V GX using Quartus II 13.1.
In the implementation, the altlvds_tx has 12 chunnels and the deserialization factor is 8 (that is, the input is tx_in[95..0]).
Simlations seems to work as I design.
However, errors below occur when I/O Assignment Analysis or Fitter executes.
Error(175001):Could not place PLL LVDS output.
(Submessage)
Error (180002): Can't place PLL LVDS output because the SERDES DPA is already driven by 2 clock and clock enable pairs (16 locations affected)
Info (175029): PLLLVDSOUTPUT_X0_Y21_N2
Info (175029): PLLLVDSOUTPUT_X0_Y22_N2
Info (175029): PLLLVDSOUTPUT_X0_Y23_N2
Info (175029): PLLLVDSOUTPUT_X0_Y24_N2
Info (175029): PLLLVDSOUTPUT_X0_Y63_N2
Info (175029): PLLLVDSOUTPUT_X0_Y64_N2
Info (175029): PLLLVDSOUTPUT_X0_Y65_N2
Info (175029): PLLLVDSOUTPUT_X0_Y66_N2
Info (175029): PLLLVDSOUTPUT_X81_Y80_N2
Info (175029): PLLLVDSOUTPUT_X81_Y81_N2
Info (175029): PLLLVDSOUTPUT_X81_Y82_N2
Info (175029): PLLLVDSOUTPUT_X81_Y83_N2
Info (175029): and 4 more locations not displayed
Error (180002): Can't place PLL LVDS output because the SERDES DPA is already driven by 2 clock and clock enable pairs (8 locations affected)
Info (175029): PLLLVDSOUTPUT_X81_Y5_N2
Info (175029): PLLLVDSOUTPUT_X81_Y6_N2
Info (175029): PLLLVDSOUTPUT_X81_Y7_N2
Info (175029): PLLLVDSOUTPUT_X81_Y8_N2
Info (175029): PLLLVDSOUTPUT_X169_Y21_N2
Info (175029): PLLLVDSOUTPUT_X169_Y22_N2
Info (175029): PLLLVDSOUTPUT_X169_Y23_N2
Info (175029): PLLLVDSOUTPUT_X169_Y24_N2
How can I work around these errors?
I'd be happy if anyone give me some advice.
Lambert
I face the same question, can you give me some help?
Lambert
