16026 Discussions
Associated Flash memory problem
FranciscoPolo
I am using the Intel IP Parallel Loader in an Arria V FPGA, I have no problem loading the IP program in the FPGA, the problem is with the flash memory used, in the application they propose CFL flash memories, which are They find all obsolete and I have not found an application manual that proposes new CFI flash memories to use.
I put an AMD compatible flash memory with CFI and when trying to record it using the Parallel Loader Flash IP application it gives me the following error:
"Can´t recognize the Flash device that attached to device 1. The Flash device is not supported by Quartus Prime software".
Could you help me find a 32 Mb Flash compatible with Quartus Prime Software and that is not obsolete.
Thanks for the help
BrusC_Intel
Hello, FranciscoPolo.
Good day,
Thank you for posting in the Intel Community Support forum.
I will move your thread to a more specialized section so it can be answered more quickly.
One of my colleagues will contact you back as soon as possible.
Bruce C.
