I would like to use Quartus II 17.1 to do the JTAG programming on MAX 10 Device - 10M08SCU169. I have discovered a problem with the error messages - "Unable to scan device chain. Can't scan JTAG chain." when I was clicking on "Auto Detect" button. The USB Blaster seems to be working correct as the Blue LED is powered ON when I was clicking on "Auto Detect" button. Next, I have opened the JTAG Chain Debugger to trouble the JTAG chain and there are 2 errors prompted on session log. See attached.Link Copied
1.ensure Blaster is correctly connected.TDO is not connected properly, a noisy TCK signal, or TDI shorted to GND 2.Check your board power supply are powered properly and also Check the voltage seen on the pins of the JTAG header to see if they are at appropriate levels. The download cable is powered by the board, so ensure your board is properly powered. 3.Ensure you blaster is working fine. https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03312011_647.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
My DECA board (also utilizing a MAX10) only works when I directly connect it to the computer's USB port and refuses programming on a (powered) hub.
Maybe worth a try.- Mark as New
Maybe HUB degrades the voltage requirement for jtag. Probe the signal and check the voltages for both cases and find out the problem. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
