I get a ASIC design which want to be verified on FPGA.
I know Quartus support "Auto gated clock convert to clock enable" recently.
From the above web, I know that case(1) can completely support gated clock conversion.
How about case(2)? Can latch-based clock gating work for gated clock conversion?
Should I do formal verification when "Auto gated clock convert to clock enable" is turned on.
How about case(3)?
Case(1): Note that enable_a is from the clock_a domain.
assign gated_clock_a=clock_a & enable_a;
assign gated_clock_a=clock_a | enable_a;
Case(2): Latch-based clock gating
always@(*) begin
if (~clock_a )
enable_a <= enable;
end
assign gated_clock_a= clock_a & enable_a ;
Case(3): Note that enable_a is from the clock_a domain.
Note that enable_a2 is from the gated_clock_a domain.
assign gated_clock_a = clock_a & enable_a;
assign gated_clock_a2 = gated_clock_a | enable_a2;
Thank you very much.
Sorry for the late response. From what I know, case 2 is allowed.
You can refer to pages 12-10 to 12-12 of this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii51006.pdf#page=10
Is case 3 a cascaded clock gating? This only works on certain devices, I think it's best you don't use this method since you're doing ASIC prototyping.
Nurina
Could someone please tell me the answer? Thank you very much.
Nurina
Hi NurinaW,
Thank you, NurinaW, very much. I understand it. About case 3, a cascaded clock gating, ASIC has different application domain so that there needs a cascaded clock gating to gate the clock for different IP and for different application domain. So, I can't cancel that.
It depends on your device. It's supported in Arria® series, Cyclone® II, Cyclone III, Cyclone IV, Stratix® II, Stratix II GX, Stratix III, Stratix IV, and Stratix V devices.
You can refer to section 2.2.3.5 here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-qpp-design-recommendations-19-1.pdf#page=65
And this help page; https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#logicops/logicops/def_synth_gated_clock_conversion.htm
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
