17043 Discussions
Automatic .Pin file generation with Quartus 15.1 upwards
Just started using Quartus again and found that it no longer creates a .pin file and that I ahve to go to the fitter report and export it by hand, is there a way this can be turned on? We ahve tools that use this to update schematics and pcb library parts so its very useful to have it! Or is there another file that's replaced it now?
David
Are you looking for it in the right place? Newer versions of the tools put these files into an 'output_files' directory in the project's folder.
Cheers,
Alex
Alex,
Just notcied your response, seems that the email notification got blocked! Your 100% correct, thanks for that!
David
