17255 Discussions
Avalon Data Pattern Checker IP, missing in Quartus Pro 22.1?
alexislms
Valued Contributor I
There is only the checker, not the generator:
Opening a project with such module, Quartus tells me the IP is missing.
It's present in the user guide 22.1:
aikeu
Hi alexislms,
I have checked the 22.1 quartus version and see a similar issue. I will further query on this matter and get back to you
Aik Eu
alexislms
Thanks, when can we expect a fix?
aikeu
Hi alexislms,
There was a case filed to engineering team, it is still pending on investigation.
Aik Eu
aikeu
Hi alexislms,
I suggest that you can use back the older quartus version which has the IP for now.
The fix will take some time to follow up.
I will close this thread first if no further question.
Aik Eu
