16597 Discussions
Avalon MM slave/master to AXI Stream Master/Slave
nt261
Hi I'm unable to connect Avalon MM slave/master to AXI Stream Master.  I'm getting error messages as attached.
1)Do we need to connect any bridge in between?
2)how to connect Avalon MM slave/master to AXI Stream Master/Slave
3)Axi slave/master to AXI Stream Master/Slave
sstrell
(Host = master, agent = slave)
Avalon memory-mapped interfaces cannot be bridged to AXI streaming interfaces (assuming we're talking about connections in Platform Designer) or vice versa.  Avalon and AXI memory-mapped interfaces can be connected to each other, but the streaming versions cannot (and you can't connect Avalon streaming to AXI streaming either).
nt261
How can we connect AXI/AXI4 slave/master to AXI Stream Master/Slave in Platform designer?
sstrell
Kenny_Tan
Sstell was right, if you want to do that, you will have to write your own custom bridge for that.
We do have example for avalon but not for axi
https://www.intel.co.jp/content/www/jp/ja/programmable/documentation/owv1467062573484.html?elq_cid=5786660_ts1605835627817&erpm_id=9056791_ts1605835627817
Kenny_Tan
Since this thread had been answered, we shall close this thread. If you still need further assistance, you are welcome to post a response within 15days or open a new thread, some one will be right with you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
