17255 Discussions
Barrel shifter coding using mux
I need help building a barrel shifter that uses multiplexers and has three columns as stated in the attachment. Please help!
What help do you need? what problems are you having doing it yourself?
--- Quote Start ---
--- Quote End ---
Yes I am new to VHDL and don't quite understand all the commands I have one barrel shifter constructed but I don't know how to combine the other two barrel shifters with the signal command and I don't know exactly how I would write the code to get all barrels to shift. I know I probably need to select a signal that acts like a switch.
Thats sounds plausible - have a go and come back here when you're having problems with your code.
--- Quote Start ---
--- Quote End ---
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.all;
entity barrel_shifter_8bit is
Port (
data: in std_logic_vector(7 downto 0);
data_out: out std_logic_vector(7 downto 0);
ctrl: in std_logic_vector(2 downto 0)
end barrel_shifter_8bit;
architecture Behavioral of barrel_shifter_8bit is
begin
with ctrl select
data_out<= data(0)& data(7 downto 1) when "001",
data(1 downto 0)& data(7 downto 2) when "010",
data(2 downto 0)& data(7 downto 3) when "011",
data(3 downto 0)& data(7 downto 4) when "100",
data(4 downto 0)& data(7 downto 5) when "101",
data(5 downto 0)& data(7 downto 6) when "110",
data(6 downto 0)& data(7) when "111",
data when others;
end architecture Behavioral;
-----This is what I have so far I'm stuck on transfering the output to the next column of the barrel shifter.
library IEEE;
Port (
component barrel_shifter_8bit1 is
Port (
input: in std_logic_vector(15 downto 0);
end component;
component barrel_shifter_8bit2 is
Port (
input: std_logic_vector(15 downto 0);
end component;
component barrel_shifter_8bit3 is
Port (
end component;
signal sig1, sig2: std_logic_vector;
begin
unit1: barrel_shifter_8bit1
port map (data7 =>input0, data6=>input1 and input2, data5=>input3 and input4,data4=>input5 and input6,
data3=>input7 and input8, data2=>input9 and input10, data1=>input11 and input12, data0=>input13 and input14,
input0 => 0);
unit2: barrel_shifter_8bit2
port map(
unit3: barrel_shifter_8bit3
port map()
end str_arch;
with ctrl select
data when others;
---- what it looks like now working on port mapping the three columns of barrel shifters. The last part is from some help I got earlier for the first column dont know how to use it yet.
