17191 Discussions
Below warning was reported for clock by Quartus Prime 18.0
XQSHEN
Software: Quartus Prime 18.0
Device: 10M16DCU324I7G
Below warning is reported after run Fitter.
What's the problem here and what should I do?
Warning (332060): Node: emmc_driver:emmc_driver_0|clk_div[2] was determined to be a clock but was found without an associated clock assignment.
Verilog code: just use 50MHz to devide to generate 12.5MHz for eMMC write FIFO. It's customized component (I defined it as eMMC driver) used in NIOS system.
 always @(posedge clk) clk_div <= clk_div + 3'd1; // clk=50MHz
 assign ddrfifo_clk = clk_div[2]; //12.5MHz
KennyTan_Altera
You may need to write a sdc and create a clock for this. You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf
KennyTan_Altera
Any update?
XQSHEN
You are right. you can close it.
