Folks:
I am writing a testbench for a pulse-width modulator and wanted to check for several hundred different values. I figured I'd use a loop for each value, but I'm not sure of the best way to confirm (using assert) that the pulse is the correct length for each value. I was planning on just using a "wait until" and then "now - output'last_event" but I want to use the loop index in a comparison with a time value, which isn't going to work. I suppose I could use some sort of inner loop that counted the clock cycles, but that seems very clunky. I'd appreciate any recommendations or links to good resources.Link Copied
Perhaps this post might help...
https://alteraforum.com/forum/showthread.php?t=6493 Combine that with a 'wait until {rising/falling edge(signal)}' and you should be able to automatically measure the mark or space width. Cheers, Alex- Mark as New
You can use the 'stable' VHDL attribute with a value consistent with the pwd command.
Example: assert pwm_out'stable(TIME) report "signal is not stable during the expected time" severity error;
