16602 Discussions
Bist code for integer based arithmetic and logical operation
HELLO,
Its PLEASURE this kind of medium TO FOR DISCUSSION OF PROBLEM REGARDING VERILOG CODE.
I am beginner of the Verilog and i am learning verilog, how to call module write testbench..etc
I REQUIRE verilog CODE THAT CAN TEST ALU USING BIST(built-in self test) METHOD (TEST PATTERN GENERATOR...> ALU......> RESPONSE ANALYZER).
ALU OPERATION FOR 4 BIT ADDITION, SUBTRACTION, MULTIPLICATION.. etc
pls help require code.
We can help you with YOUR code, not write it for you. Post the code you are having a problem with.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
thank you sir but i had made code which is only pattern generator and fault inserting accept the signature analyzing.... can you provide me code for signature analysis or guide me how i give output of cUT and that give to MISR(MULTI INPUT SIGNATURE REGISTER). and how MISR will give golden response so I can compare and find the response is good or not . so i can decide whether my alu is faulty or not .
As stated, I don't think folks are going to write code for you. Post what you have so we can take a look.
