17268 Discussions
Block Diagram File with Parameters - Generate VHDL File not possible (for Simulation)
please tell me if i got something wrong in my workflow:
1. My Top-Level File is a BDF (Block Diagram File)
2. I placed VHDL Blocks including Generics which are seen as parameters in the BDF. There i can set a parameter e.g:
parameter
value
type
COUNT_MAX
1000
Signed Integer
SOMETHING_ELSE
20.5
Float
I even can write a Variable instead of the number, e.g:
parameter
value
type
COUNT_MAX
GLOBAL_PARAM_CNT_MAX
Signed Integer
SOMETHING_ELSE
GLOBAL_PARAM_RANDOM
Float
3. The GLOBAL_PARAM_CNT_MAX can be set by the "Parameter Primitive" or e.g. in the Settings->Comiler Settings-> Default Parameters
4. Everthing is fine, the design is synthesizable and the Parameters can be changed and set up by a Revision very easily! Perfect!
Now my Problem. I want to simulate my design by the "build in" modelsim altera startet edition. So, as far as i understand and already did earlier, i have to generate a VHDL of the BDF and write a Test Bench for ist. Very easy in theory. Since there are Parameters inside the BDF, it is not possible to generate a VHDL by "File->Create/Update->Generate HDL File" as it shows up the error:
Error (275082): Illegal values "GLOBAL_PARAM_CNT_MAX " for parameter "COUNT_MAX ". The type is "Signed Integer".
Error (12153): Can't elaborate top-level user hierarchy
Error: Quartus Prime Create VHDL File was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 521 megabytes
Error: Processing ended: Tue Jun 27 18:16:10 2017
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
So, how can i use parameters (in any way?) on a very clear BDF File and somehow do a design simulation in Modelsim? -> I have LOTS of parameters. Just replacing the parameters by direct values for simulation/HDL file generation is no solution :-( Or is it simply a BUG on Quartus Prime Version 16.1?
Thank you very much!
Probably not a bug - just weaknesses in BDF.
Easiest option is probably just write in VHDL in the first place.
