16333 Discussions
Bug ID: 18012993764: nios2-elf-gcc.exe: error: CreateProcess: No such file or directory
TrainMan
Found patches for Quartus Pro and Standard editions at:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2020/nios2-elf-gcc-exe--error--createprocess--no-such-file-or-directo.html?wapkw=nios2-elf-g%2B%2B.exe%3A%20error%3A%20missing%20argument%20to%20%27-msys-crt0
None listed for the Lite edition.  Tried the standard edition patch and it fixed one of two error messages but still have the Argument error "nios2-elf-g++.exe: error: missing argument to '-msys-lib='".
Any fixes for the Quartus Lite edition?
Isaac_V_Intel
Hello TrainMan,
I was talking with the team and you can use the patch for standard edition on the lite edition. But you need to use 20.1 or 19.1.
Isaac Vazquez.
GChou3
Hi Isaac,
do you have patch for 20.1.1-720 for fixing this issue?
there is same issue when using 20.1.1-720.
