17255 Discussions
Bus contention because of the FPGA.
Hey guys,
I have a BIDIR pin in my design file now that is not connected to any logic. Since that pin is connected to a DSP, I have been having bus contention problems. I know for sure that the FPGA is the culprit.
The only difference between a functional design (when the pin is connected to some logic) and a non-functional design (pin is not connected to any logic) is:,
Info: Pin GPIO[1] has VCC driving its datain port
Currently, on the oscillioscope, yes I can see that the FPGA is driving the pin high, how do I avoid that?
Compilers do not honour your assignments if it does not do anything.
I wonder why you want bidir pin but without any logic. At least you can insert dummy logic to read/write the pin
A bus-line must be set to 'Z' (tri-stated) in idle state. You can do this also for unused bus lines.
GPIO <= (others => 'Z');
If the port is not synthesized due to a lack of logic, you can try setting the Unused Pin behavior to Input tri-stated with weak pull-up.
Thanks adding a when else code.. with tri-state during idle has solved it.
