HAI,
CAN ANYBODY RESOLVE THIS ERROR
# FATAL ERROR while loading design
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./INT_TOP_run_msim_rtl_vhdl.do PAUSED at line 22
AND THE INT_TOP_run_msim_rtl_vhdl.do FILE IS COPIED HERE.
transcript on
if {[file exists rtl_work]} {
vdel -lib rtl_work -all
vlib rtl_work
vmap work rtl_work
vlog -vlog01compat -work work +incdir+C:/Users/user/Desktop/FPGA\ TESTING_INTEG\ NODE/JAN12\ FILES\ FROM\ KP/INT_TOP_13JAN2021/db {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/db/plll_altpll.v}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/INT_TOP.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/adc_interface_logic.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/fifo.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/digipot_config.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/spi_slave.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/plll.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/psram_buffer.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/psram.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/dpram.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/control_logic.vhd}
vcom -93 -work work {C:/Users/user/Desktop/FPGA TESTING_INTEG NODE/JAN12 FILES FROM KP/INT_TOP_13JAN2021/simulation/modelsim/INT_TOP_TB.vhd}
vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L rtl_work -L work -voptargs="+acc" INT_TOP_TB
add wave *
view structure
view signals
run -all
PLEASE HELP ME
May I know you are using Quartus Pro or Quartus std? If you use Quartus std, we do have a native link to help setting up it.
Any update?
We do not receive any response from you to the previous question. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
