17267 Discussions
CRC error check in verilog
m_kumar
Hi
can anyone help me how to implement an verilog code to check data integrity using CRC for polynomial calculation x11+x8+x7+x6+x4+x3+x1+1.
i want to check data integrity at receiver side.
regards
ak6dn
Valued Contributor III
Did you use the solution referenced in your previous post:
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Help-needed-for-implementing-CRC-polynomials-in-verilog/m-p/1206976#M66104
Don't start a new post unless you really need to change the subject dramatically.
ak6dn
ak6dn
FYI just for fun I followed the instructions in the previous post for a CRC generator with a data width of 1, polynomial width of 12, with your requested polynomial, and it generated the following results:
m_kumar
sir is that logic work for 300Mhz clock source.
thanks in advance
ak6dn
Well, that depends on a lot of things that have not been specified.
Device family, speed grade, layout.
So no way to say at this point.
The implementation is register based with probably just one level, or two at most, in the feedback logic.
So if 300MHz is a valid internal clock for a device, I would say a definite maybe.
