17158 Discussions
Camera Link Transmitter Design
m_kumar
Hi sir/madam.
I'm designing an camera link logic to transmit   rgb data to through camera link. I stuck with how to generate clock signals for both transmitter side and receiver side.
I studied one manual it was saying need to generate two clocks.
  1. base pixel clock.
  2. lvds bit clock ( i,e base pixel clock *7 /2 )
can i get any design references for to solve this problem
EngWei_O_Intel
Hi Kumar
Are you trying to create a LVDS SERDES function in FPGA or clock generation in FPGA?
Eng Wei
m_kumar
Yes sir i'am using serializer in transmitter side and deserializer in receiver side.
EngWei_O_Intel
Hi Kumar
You can generate example design through IP Catalog following spec here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug_altera_lvds-17-0.pdf
Or you can search for relevant functional design example here:
https://fpgacloud.intel.com/devstore/platform/?search=LVDS
Eng Wei
m_kumar
Thank you, i will update result soon.
EngWei_O_Intel
Hi Kumar
Since there is no update on this, we will transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
