17267 Discussions
Can SignalTap work without clock?
ldm_as
Hi All,
Can SignalTap work without clock? I actually only want to see the logic values of the signals, which are not timed by clock (async resets, etc)
Thank you!
sstrell
If you want to see internal signal levels during runtime without a clock, use In-System Sources & Probes instead of Signal Tap.
#iwork4intel
SreekumarR_G_Intel
No, you must use clock for internal logic analyzer data acquisition to sample the data on the rising edge or falling edge etc.
Can you try use the global clock in your design and add the not timed signal into that stp file ?
I am sure in way above you can find the changes in not timed signal .
Also here is the signaltap user guide for your reference,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/signal.pdf
Thank you ,
Sree
sstrell
#iwork4intel
