17254 Discussions
Can an IPX File handle a **?
TuckerZ
New Contributor II
I wanted to know if the latest version of Quartus Pro allows for ** to be used inside of path element in an .ipx file.
I tried using a ** in a path element with version 21.1 of Quartus Prime Standard and it didn't work. The user guide makes no reference as to whether this is possible.
example:
<library>
    <message>Loading now from ip.ipx</message>
    <path path="../ip/**/*" />
</library>
However, the following does work as intended:
<library>
    <path path="../ip/*/*" />
</library>
SyafieqS
Recent Quartus does not allow for ** to be used inside of path element in an .ipx file. You may need to work around it using *.
SyafieqS
What version or Pro does this work?
Is it 23.2?
TuckerZ
New Contributor II
Yup, That's my question. As stated, the noted behavior was observed in "version 21.1 of Quartus Prime Standard ".
SyafieqS
I am looking into this
SyafieqS
TuckerZ
New Contributor II
Alright. I would like to request that IPX files can also use ** since other places of Quartus can use ** when searching for IP. Aligning these differences in behavior can make for a smoother software.
SyafieqS
I will for a enhancement regarding this and thank you for you valuable feedback.
