17191 Discussions
Can an older MAX II (EPM1270T144C5N) POF file be imported and reversed into logic equations or a design file of sorts?
MMeye20
I have a very old .POF file, for the above device, that I do not have the original design files for. We are redesigning the circuitry around the CPLD and would like to find if there was a reverse process to generate a set of logic equations. It would save time from having to black box inspect the HW timing directly and other methods we'd employ. In searching these forums, I'm not optimistic.
JohnT_Intel
Unfortunately there is no way to reverse engineering on the POF file. You will need to find the project file.
