I can't see the optimization report generated by earlier versions i.e the ${KERNEL}.log file. When I moved to intel fpga sdk 17.0. I am not talking about the html reports (they are there alright). Something I missed ? I used the following command line: aoc -c -o build/${KERNEL}.aoco --report --fp-relaxed --fpc device/${KERNEL}.cl normally I used to get a log at build/${KERNEL}.log with detail descriptions of each loop. Thanks in Advance chaudhurLink Copied
That info in the text report has been removed; the info has been moved to the "Loop Analysis" section of the HTML report.
I am not really happy about the fact that Altera is moving everything into the HTML report since accessing that big report with all those files inside of it is a huge paint over a slow network; the text report and the old HTML report which was just one single file were much more convenient for network access.
Topic Options
