16985 Discussions
Can someone please help me. I cant seem to figure out what is causing this error: Error (10500): VHDL syntax error at mult_control_ex.vhd(58) near text "END"; expecting "begin", or a declaration statement
JRamo9
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity mult_control is port(
      clk, reset_a, start : in std_logic;
      count : in unsigned (1 DOWNTO 0);
      input_sel, shift_sel : out unsigned(1 DOWNTO 0);
      state_out : out unsigned(2 DOWNTO 0);
      done, clk_ena, sclr_n : out std_logic
end mult_control;
-architecture logic of mult_control is
   type state_type is (idle, lsb, mid, msb, calc_done, err);
   signal current_state: state_type;
   signal next_state: state_type;
 begin
   process (clk, reset_a) begin
      if reset_a = '1'; then
         current_state <= idle;
      else rising_edge(clk) then
         current_state <= next_state;
      end if;
   end process;
   process (current_state, start, count) begin
      case current_state is
         when idle =>
            if start = '1' then
               next_state <= lsb;
            else
               next_state <= idle;
            end if;
         when lsb =>
            if start = '0' then
            if (count = "00") then
               next_state <= mid;
            else
               next_state <= err;
            end if;
         when mid =>
            if start = '0' then
            if (count = "01") then
               next_state <= mid;
            elsif start = '0' then
            if (count = "10") then
               next_state <= msb;
            else
               next_state <= err;
            end if;
         when msb =>
            if start = '0' then
            if (count = "11") then
               next_state <= calc_done;
            else
               next_state <= err;
            end if;
         when calc_done =>
            if start = '0' then
               next_state <= idle;
            else
               next_state <= err;
            end if;
         when err =>
            if start = '0' then
               next_state <= err;
            else
               next_state <= lsb;
            end if;
         end case;
   end process;
SAR
HI,
First of all you can maintain some coding standards or at least by giving spacing /Tab which will help in eliminating many errors.
I can see many syntax error few are listed below
Statements Syntax error
  • -architecture logic of mult_control is -> -
  • if reset_a = '1' ; then -> ;
  • else rising_edge(clk) then -> else or elsif
  • architecture is not ended. ->No architecture logic;
  • few Conditional Control are missing end statements by having spacing/Tab we can eliminate such.
KhaiChein_Y_Intel
Hi JRamo9,
Kindly check if the functionality of the edited version is correct
library IEEE;
end mult_control;
 begin
   if reset_a = '1' then
   elsif rising_edge(clk) then
   end if;
  end process;
     when idle =>
      if start = '1' then
        next_state <= lsb;
      else
        next_state <= idle;
      end if;
     when lsb =>
      if start = '0' then
        next_state <= mid;
      else
        next_state <= err;
end if;
end if;
     when mid =>
      if start = '0' then
next_state <= mid;
elsif (count = "10") then
next_state <= msb;
else
next_state <= err;
end if;
      end if;
     when msb =>
      if start = '0' then
else
next_state <= err;
end if;
      end if;
     when calc_done =>
      if start = '0' then
        next_state <= idle;
      else
        next_state <= err;
      end if;
     when err =>
      if start = '0' then
        next_state <= err;
      else
        next_state <= lsb;
      end if;
     end case;
  end process;
end logic;
