Can't find JTAG server
AWann1
I'm attempting to use the quartus 18.1 programmer to program a cyclone III LS FPGA. I have successful used this installation and USB Blaster to program cyclone Vs with no issue.
I created a new .jic file for the cyclone III, But when I attempt to program it, I get the error "can't find JTAG server"
Is it possible this version of the programmer is too new to program the cyclone III?
Farabi
May I know which version you create the design for MAX?
you should use same version of Quartus programmer with the version you use for design the MAX.
regards,
Farabi
Fakhrul
Hi AWann1,
I wish to follow up with you about this case. Do you have any updates?
Otherwise, this thread will be idling and marked as inactive, thus it will be transitioned to community support because there is no update received from you in a while.
Fakhrul
