Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Can't resolve multiple constant drivers for net "enableit" error
Error (10028): Can't resolve multiple constant drivers for net "enableit" at Transmit6.vhd(156) signal enableit : STD_LOGIC; signal dropornot : STD_LOGIC; signal rxdv2 : STD_LOGIC; signal txdata8 : STD_LOGIC_VECTOR(7 DOWNTO 0); signal rxdata8 : STD_LOGIC_VECTOR(7 DOWNTO 0); signal rxdata_4b: std_logic_vector(3 downto 0); signal rxdv_4b: std_logic; signal txdata_4b: std_logic_vector(3 downto 0); signal txen_4b: std_logic; signal col2 : STD_LOGIC; signal reset2 : STD_LOGIC; signal CheckSumResult : STD_LOGIC_VECTOR (31 DOWNTO 0); signal CheckSumValid : STD_LOGIC; constant disableit : STD_LOGIC := '0'; constant emptytwobits : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00"; --constant whilelooptrue :STD_LOGIC := '1'; begin enableit <= '1'; H2:CRCGen port map( clk => CLOCK_50, --: IN STD_LOGIC; data => payload, -- : IN STD_LOGIC_VECTOR (7 DOWNTO 0); datavalid => enableit, --: IN STD_LOGIC; empty => emptytwobits ,--: IN STD_LOGIC_VECTOR (1 DOWNTO 0); endofpacket => enableit, --: IN STD_LOGIC; reset_n => disableit, --: IN STD_LOGIC; checksum => CheckSumResult, --: OUT STD_LOGIC_VECTOR (31 DOWNTO 0); crcvalid => CheckSumValid --: OUT STD_LOGIC ); H1:ethernet port map ( rxclk => CLOCK_50, -- receive clocks txclk => CLOCK_50, -- transmit clocks -- rx inputs rxdata_4 => rxdata_4b, rxdv_4 => rxdv_4b, -- receive data valid -- tx outputs txdata_4 => txdata_4b, txen_4 => txen_4b, -- tx enable -- status inputs col => col2, -- collision indicators -- system clock; clk => CLOCK_50, reset => reset2, -- faster clock used for synchronization sync_clk => CLOCK_50, -- data I/O rxdata => rxdata8, -- 8 bits wide rxdv => rxdv2, -- receive data valid txdata => txdata8, -- 8 bits wide txen => enableit, -- status outputs drop => dropornot -- indicates the current frame should be dropped ); process(CLOCK_50) VARIABLE last_clk : std_logic := '0'; VARIABLE counter : integer := 0; VARIABLE last_counter : integer := 0; begin --while (whilelooptrue = enableit) loop if SW(0) = '1' then enableit <= '1'; -- Error happen here if (CLOCK_50 = '0') AND (last_clk = '1') then if (counter = 0) then txdata8 <= preamble; end if; if (counter = 1) then txdata8 <= preamble; end if; if (counter = 2) then txdata8 <= preamble; end if; if (counter = 3) then txdata8 <= preamble; --end end if; if (counter = 4) then txdata8 <= preamble; end if; if (counter = 5) then txdata8 <= preamble; end if; if (counter = 6) then txdata8 <= preamble; end if; if (counter = 7) then txdata8 <= SFD; end if; if (counter = 8) then txdata8 <= dest_mac_addr1; end if; if (counter = 9) then txdata8 <= dest_mac_addr2; end if; if (counter = 10) then txdata8 <= dest_mac_addr3; end if; if (counter = 11) then txdata8 <= dest_mac_addr4; end if; if (counter = 12) then txdata8 <= dest_mac_addr5; end if; if (counter = 13) then txdata8 <= dest_mac_addr6; end if; if (counter = 14) then txdata8 <= src_mac_addr1; end if; if (counter = 15) then txdata8 <= src_mac_addr2; end if; if (counter = 16) then txdata8 <= src_mac_addr3; end if; if (counter = 17) then txdata8 <= src_mac_addr4; end if; if (counter = 18) then txdata8 <= src_mac_addr5; end if; if (counter = 19) then txdata8 <= src_mac_addr6; end if; if (counter = 20) then txdata8 <= wholepacketlength1; end if; if (counter = 21) then txdata8 <= wholepacketlength2; end if; if (counter = 22) then txdata8 <= payload; end if; if (counter = 23) then txdata8 <= emptyhex; end if; if (counter = 24) then txdata8 <= X"10";--CheckSumResult; end if; last_counter := counter; counter := counter + 1; end if; if (CLOCK_50 = '1') AND (last_clk = '0') then if (counter >= 25) then enableit <= '0'; end if; end if; else enableit <= '0'; end if; --end loop; last_clk := CLOCK_50; end process; end architecture transmitarch;
Highlighted
you're setting enableit to '1' at the top of the file and setting inside the process. You can only set it in 1 place (inside or outside the process).
Highlighted
it success compiled after followed your advice, thank you very much, very helpful and expert suggestion. Really thanks.
