I can't run functional stimulation in Quartus 13.0 with Linux. Are there any solutions?
I don't think the path to the Modelsim executable is correct.
It should be something similar to .../.../<version>/modelsim_ase/linux32aloem
Please also check the OS is supported.
Richard Tan
Did actually you install the ModelSim software package?
It is a separate .run install file from the Quartus .run file.
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
It didn't work
Instead of using the waveform simulation, could you try to use the Nativelink simulation flow and see if it works for you?
May I know do you able to run the Nativelink simulation flow?
Richard Tan
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support.
We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to let us know.
Thank you for reaching out to us!
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
