17040 Discussions
Can't simulate ALTERA_PLL
I'm using Quartus 12.0 SP2 and standalone ModelSim PE. I have a design in Cyclone V with a MegaFunction generated ALTERA_PLL. The generated simulation source file mypllname.vho which instantiates altera_pll only references:
LIBRARY altera_lnsim;
USE altera_lnsim.altera_lnsim_components.all;
(in addition to ieee).
When I try to sim my testbench, ModelSim reports that altera_pll is not bound. Shouldn't it be in altera_lnsim? I used msim_setup.tcl to compile the Altera libraries. It called for two files to be compiled into the altera_lnsim library. altera_lnsim_components.vhd compiled OK but altera_lnsim_for_vhdl.sv did not, since it is not in the Quartus distribution (I'm using the Web freebie if that makes a difference).
Hopefully I'm missing something obvious. Thanks for any info and advice.
Did you figure out how to solve this? I am having the same error with altera_pll supposedly unbound.
--- Quote Start ---
--- Quote End ---
To solve this trouble, you have to modify the altera_lnsim_components.vhd file. Copy this file in local and do the following modification:
Extract of the code of the altera_pll component
pll_vco_div :integer := 0;
pll_output_clk_frequency :string := "0 MHz"; -- Paste the original code here
pll_bwctrl :integer := 0;
pll_cp_current :integer := 0;
pll_fractional_division :integer := 0;
pll_fractional_cout :integer := 24;
-- pll_output_clk_frequency :string := "0 MHz"; -- Original code
