Is it possible to drive nets in the core via SignaltapII tool? I do not find much information regarding this online. ThanksLink Copied
No, you can use "In System Sources & Probes" feature. It can be instantiated in your design. Then you can drive nets in the core using JTAG.
--- Quote Start --- No, you can use "In System Sources & Probes" feature. It can be instantiated in your design. Then you can drive nets in the core using JTAG. --- Quote End --- Hello Msj, thank you very much. It helped.
