Hi all,
I'm new on using Intel JESD204B IP Core and met some problems. Since it's my first time trying to implementing the JESD204B IP-Core, I directly follow the intel fpga jesd204b design example step-by-step. But I couldn't get the desired output files as the user guide instructs. **Link of user guide: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-dex-a10-jesd204b.pdf According to page 4 of user guide, the output file structure should be something like attached pic_1. When I click the "Generate Example Design" button with preset configuration in IP Parameter Editor Pro, multi errors occurred. The message said 'Cannot run program "sys-script" (in driver\QII Installed_path\version\ip\a;tera\altera_jesd204b\src\top)'. Looks like some parts missing in QuartusII tool chain, but I didn't modify anything after installation. An of course, I've tried to re-install QuartusII Prime Pro (30-Days Trial) with version 16.1/17.0/17.1, none of these works normally as user guide described. Did I miss any step or there's some other patch/tools I need to install? Thanks in advance!Link Copied
