Recently I have installed intel quartus prime pro and using it. I have tried to run modelsim, and it shows this error.
" The code execution cannot proceed because MSVCR120.dll was not found. Reinstalling the program may fix this problem."
I am unable to run it because of this error. I have searched about the error and found a answer that , install MS VC++ and I have installed 2013 version of that also..
Kindly help me to run this..
Thanks and Regards
MuralikumarM
Please check that the LM_LICENSE_FILE is directed to a license file. Modelsim Intel Edition required a license.
How to set LM_LICENSE_FILE:
In the command prompt:
setx LM_LICENSE_FILE <license file path>
example: C:\intelFPGA_pro\21.1\license.dat
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
You may checkout the link below for the solution.
Let me know if it helps.
Richard Tan
Thanks for your response.
I found the dll file and replaced it with new one but again i am getting same error.
Please provide other possibilities to try and solve the problem.
MuralikumarM
Do you download the Modelsim installer from our Download Center for FPGAs?
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
Try to uninstall the current Modelsim and install the Modelsim - Intel FPGA edition.
Let me know if the issue persists.
Richard Tan
You may checkout the below link for the solutions that might helps to solve the issue.
Richard Tan
all the things above given was tried and still the same error showing.
regards
MuralikumarM
Hmm that's weird. Have you try to install in other machine and observe the same issue?
Could you share a screenshot of the shown error?
Richard Tan
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
sorry for the late reply, caught on some other work.
actually i didnt tried installing on other PC. but I tried to install the quartus prime lite version.
and while running the simulation library compiler it shows as follows
Info: Command: quartus_sh --simlib_comp -tool modelsim -language vhdl -tool_path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ -directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite -rtl_only
Info: Quartus(args): -tool modelsim -language vhdl -tool_path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ -directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite -rtl_only
Info: Changing the current directory to output directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite ..
Info: Using Path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ that was set in EDA Simulation Library Compiler Options
Info: Generating commands to compile library altera ...
Info: Generating commands to compile library lpm ...
Info: Generating commands to compile library sgate ...
Info: Generating commands to compile library altera_mf ...
Info: Generating commands to compile library altera_lnsim ...
Info: Executing command file containing library compilation commands
Info: Unable to checkout a license. Vsim is closing.
Error: ** Error: Invalid license environment. Application closing.
Info: Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Info: Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference)
Info: 1. MGLS_LICENSE_FILE
Info: 2. LM_LICENSE_FILE.
Error: Compilation was NOT successful. 1 errors, 0 warnings
Kindly do the needful
MuralikumarM
Richard Tan
