17256 Discussions
Cannot run SignalTap II Logic Analyzer. SignalTap II File is not compatible with the file programmed in your device
笔书香
Quartus Prime 15.1 Standard Edition Version Found: v15.1
AnandRaj_S_Intel
which device is used for your design?
can you attache the error message & .qsf file?
Point to note
  1. Project Navigator should have .stp file.
  2. Also go to Assignments -> Settings -> SignalTap II Logic Analyzer->Enable SignalTap II Logic Analyzer ->browse the path of the stp.
  3. Power cycle your board.
Anand
