Attempting to learn Verilog right now. I am currently running through Verilog HDL by Palanatkir and am using Quartus Prime Lite as my current EDA. I am very new at this but just wondering, the book has us code a stimulus block as one of our very first exercises. I cannot figure out how to get Quartus to compile with it, as Quartus just states that the top level block has no logic.
Here is my code:
module stimulus;
reg clk;
reg reset;
wire q;
R_CC rcc0(q, clk, reset);
initial
clk = 1'b0; // set clk to 0
always
# 5 clk = ~clk; // toggle clk every 5 tu
initial
begin
reset = 1'b1;
# 15 reset = 1'b0;
# 180 reset = 1'b1;
# 10 reset = 1'b0;
# 20 $finish; // terminate sim
end
initial
$monitor($time, " Output q = %d", q);
endmodule
// module - basic building block of Verilog
// Ripple Carry Counter
module R_CC(q, clk, reset);
output q; // io signal and vector decl
input clk, reset;
T_FF tff0(q, clk, reset);
T_FF tff1(q, q, reset);
T_FF tff2(q, q, reset);
T_FF tff3(q, q, reset);
endmodule
module T_FF (q, clk, reset);
output q;
input clk, reset;
wire d;
D_FF dff0(q, d, clk, reset);
not nl(d, q); // not is a Verilog primative
endmodule
module D_FF(q, d, clk, reset);
output q;
input d, clk, reset;
reg q; // wtf
always @(posedge reset or negedge clk)
if (reset)
q <= 1'b0;
else
q <= d;
endmodule
Maybe I am using the wrong tool? Should I be using ModelSim or something similar?
This is a testbench, and intended to be run in a simulator. Quartus is a tool for compiling code for FPGAs, and not a proper simulator (it does have a very basic simulator, but it doesnt understand testbenches properly)
This code needs to be ruin in something like ModelsimThank you!
RTL that you can implement in the FPGA needs to be "synthesizable" So in the code above things like# and $monitor do not map to hardware resources that are inside the FPGA and are provided in the language for the reasons Tricky said. If you google "synthesizable verilog" you'll find a lot of topics on this to help you identify what parts are synthesizable and which are simulation only. In Quartus there are a bunch of templates you can refer to which should all be synthesizable, with a verilog file open in Quartus go to Edit --> Insert Template and navigate to the verilog templates to see examples of how you code various synthesizable blocks.
Hey I forgot to read this at the time (and I think I missed it) because school had started to ramp up and this brick wall kind of discouraged me but, I just started to get back to studying Verilog on my own.
I actually had the exact same problem and ended up google searching back to my original question and this helped so much. Verilog templates are great examples and explain a lot. Appreciate it so much.For more complete information about compiler optimizations, see our Optimization Notice.
