Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Cannot simulate ALTRCLKCTRL
Hello everyone,
I am trying to use ALTCLKCTRL IP in my design. The project compiles just fine, but when I try to simulate it using ModelSim (using NativeLink feature in Quartus II 16.0), I get the following errors:
# Loading altclkctrl_0.clk_gate_altclkctrl_0_sub# ** Error (suppressible): (vsim-10000) C:/EPCQ_update/core/clk_gate/simulation/submodules/clk_gate_altclkctrl_0.v(56): Unresolved defparam reference to 'sd1' in sd1.clock_type.# Time: 0 ps Iteration: 0 Instance: /tb_epcq_update/UUT/dclk_gate/altclkctrl_0/clk_gate_altclkctrl_0_sub_component File: C:/EPCQ_update/core/clk_gate/simulation/submodules/clk_gate_altclkctrl_0.v# ** Error (suppressible): (vsim-10000) C:/EPCQ_update/core/clk_gate/simulation/submodules/clk_gate_altclkctrl_0.v(57): Unresolved defparam reference to 'sd1' in sd1.ena_register_mode.# Time: 0 ps Iteration: 0 Instance: /tb_epcq_update/UUT/dclk_gate/altclkctrl_0/clk_gate_altclkctrl_0_sub_component File: C:/EPCQ_update/core/clk_gate/simulation/submodules/clk_gate_altclkctrl_0.v# ** Error (suppressible): (vsim-10000) C:/EPCQ_update/core/clk_gate/simulation/submodules/clk_gate_altclkctrl_0.v(58): Unresolved defparam reference to 'sd1' in sd1.lpm_type.# Time: 0 ps Iteration: 0 Instance: /tb_epcq_update/UUT/dclk_gate/altclkctrl_0/clk_gate_altclkctrl_0_sub_component File: C:/EPCQ_update/core/clk_gate/simulation/submodules/clk_gate_altclkctrl_0.v# Error loading design
Did anyone try using ALTCLKCTRL IP and had any success simulating the block. Any help is appreciated.
Yev
Hi Yev,
Did you resolve this problem? I'm having the same issue using Quartus Prime Lite Edition.
Steve
Hi Steve,
Apparently, there is a bug that prevents Quartus to auto-generate a good working .v file for simulation. I did not have time chasing the problem, but instead abstracted out the block for simulation.
Yev
Hi Yev,
Many thanks for your reply. I will not waste any more time trying to chase this issue but will do what you did and remove the module for simulation.
Steve
