17252 Discussions
Cannot update Quartus with Patch
Ethan12345
I am trying to update Quartus with this patch:
https://www.intel.com/content/www/us/en/support/programmable/articles/000088789.html
Unfortunately, I am running into a problem with the installer, where the installer cannot automatically locate my installation directory of Quartus, and all attempts at manually locating it have failed, returning the following message:
Where is the Quartus installation directory located?
Ethan
Nurina
You may start at the default installation path: https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/installation-path.html
If that doesn't work, you can follow the below procedure since you are using Windows:
  1. Search for the Quartus software at the Start Menu
  2. Right-click and select Open File Location. You have found the installation directory.
Nurina
sstrell
I think you have to point to the bin64 directory inside the quartus directory, not the quartus directory itself, since bin64 is where the .exe lives.
Nurina
Can you provide some updates?
Nurina
Nurina
We do not receive any response from you on the previous question/reply/answer provided. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
