17254 Discussions
Common Flash Interface (CFI) Pins
Dear community,
I want to connect an external 16-bit flash to my Cyclone V GX.
It would be very desirable to be able to program the flash directly with the Quartus II programmer.
As far as I understood this will be the case if the common flash interface supports the flash.
Can I use any pins of the Cyclone V to connect the flash, or are specific pins reserved for use with the common flash interface?
Many thanks.
Cheers,
Adam
Your understanding is essentially correct. For a little further reading I'll point you at application note: an-458-2.2 (http://www.altera.com/literature/an/an458.pdf) which discusses all manner of using FLASH and more. Have a look at the "implementing the advanced boot copier example" section from page 12, which talks you through lots of options and guides you through programming.
As for pin selection - you're pretty free to choose what you like, subject to ensuring you connect to (one or more) FPGA I/O banks operating at an appropriate voltage for your chosen FLASH device. My only recommendation is, having chosen a pin out, you run it through Quartus as a sanity check. I'd recommend this regardless of what you're connecting up to an FPGA. Always put a basic design together and run it through the tools.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
Hi Alex,
Thanks a lot!
Cheers,
Adam
