17255 Discussions
Compiling and Linking Your Kernels or Object Files without Building Hardware (-rtl) which don't work !
caron
when I use " aoc -rtl <your_kernel_filename1>.cl". it issue an error :
aoc: Running OpenCL parser....
error: unknown argument: '-rtl'
Error: OpenCL parser FAILED.
Refer to hello_world/hello_world.log for details.
HRZ
Valued Contributor III
I would guess you are using an older version of the compiler in which the -rtl switch was not available. This switch was added in v18.0 or 18.1 (don't remember exactly).
KhaiChein_Y_Intel
Hi Caron,
May I know what version you are using?
caron
Hi , thank you for your response !
my version is :
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 17.1.1 Build 273
Copyright (C) 2017 Intel Corporation
Maybe it is the version's problem.. How can I update the version ?? thank you .
HRZ
Indeed the -rtl switch is not available on Quartus v17.1.x. You can download all versions of Quartus from here:
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
However, you should make sure to use a version of Quartus that is compatible with the OpenCL BSP of your board. Consult the documents from your board manufacturer to determine what version of Quartus to use.
MMATT35
Hello KhaiY_Intel,
I have the same issue with this version :
Version 19.1.0 Build 670 Standard Edition
Copyright (C) 2019 Intel Corporation
I downloaded this version : https://fpgasoftware.intel.com/opencl/19.1/?edition=standard&download_manager=direct
and the associated documentation explain howt to use -rtl : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf
Do you knouw why have this error ?
Thank you
KhaiChein_Y_Intel
Hi MMATT35,
This forum thread has been transitioned to community support. Can you open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
KhaiY
