16694 Discussions
Conbinational group instead of regestered group
VitPri
Hi all,
 I am new to FPGA and Quartus and just truing to work with it. I am using Quartus Prime Lite edition 22.1. on Win 10.
 I write a sample module with 3 always block doing just simple stuff. As counter variables I assign reg[7:0] r_cnt...
but after 3 variables  all other reg[] suddenly becomes combinational groups instead of registered like it was before so that u_cnt,b_cnt,l_cnt are regestered group  and b_bit become combinational group and all variables that I am creatine going into combinational groups.
How one can fix this issue?
Here is the code:
module controller (
input clk,
input las_en,
input Rx,
output reg las1,
output reg las2,
output reg u_clk
reg[15:0] u_cnt;
reg[5:0] b_cnt;
reg[5:0] l_cnt;
reg[7:0] d_bit;
reg l_flg,Rx_flg;
reg[7:0] dat_in;
initial begin u_clk = 0; l_flg = 1;Rx_flg = 0; las1 = 0; b_cnt = 0;bit = 0; dat_in = 0; end
always @(posedge clk) begin // lasers pulse control
if (las_en & l_flg) begin
    las1 = 1; las2 = 1;
    l_flg = 0;
end
if(l_flg == 0)l_cnt = l_cnt + 1;
if(l_cnt == 25) begin
   las1  = 0; las2 = 0;
   l_cnt = 0;
    l_flg = 1;
end
end
always @(posedge clk) begin // UART clk
if(Rx==0) Rx_flg = 1;
    if(Rx_flg) begin
     u_cnt = u_cnt+1;
     if(u_cnt== 109) begin u_cnt = 0; u_clk = ~u_clk; b_cnt = b_cnt + 1;end
     if(b_cnt== 18 )  begin b_cnt = 0; Rx_flg = 0; end
    end
end
always @(posedge u_clk) begin
bit = bit + 1;
dat_in[bit] = Rx;
if(bit==10) bit = 0;
end
endmodule
FvM
Valued Contributor III
Where do you see variable classification as registered or combinational? All variables assigned in a clocked always block are inferring registers, so the variables in the example codes. However, due to the usage of blocking assignments, some variables are also used to hold combinational intermediate results, e.g. bit in the last block. The registered value is first increased, than the new value is immediately used as index and in a compare operation. The last assigned value is written to register again when exiting the always block.
VitPri
Hi FvM,
I am checking status of variables in waveform editor when I am trying to add variable to watch them. And in main code when you are right click on variable -> locate node  and if it is registered group you can see menu locate in ... and if it is combinational group - locate  node menu are not accessible.
So is it possible to avoid this or fix it? And why first 3 variable are registered and any other not? Declaration and usage are the same.
thank you
sstrell
Can you show some screenshots of what you are seeing?
VitPri
Hi sstrell, here is screenshots and project files.
in Node finder picture you can see that some variables are in Combinational and some in Registered groups. But all variables decaled as reg [].
Even in code by trying to locate node you can see that some variables are recognized and can be selected but not variables that was "converted " in Combinational group.
FvM
You should have mentioned that waveform editor is a Questa feature.
I have a problem that some variable names mentioned in your first post can't be found in the code, e.g. b_bit. So it's impossible to see which code details are causing the reported effects. It can be either expectable because the variables have lost their register function or it's just a bug. Personally I'm using classical ModelSim testbenches and GUI for simulation, didn't yet use waveform editor.
VitPri
Hi FvM,
you are right I post code with changes.
I post project and pictures of how I was checking variable status.
About ModelSim vs Waveform may be it doesn't matter much because it can be  can seen in pictures that when I am trying to locate node from main editor I can locate variable if it is registered and not if it is combinational. So you can easy see variable status even outside of simulation.
I change blocking assignments to unblocking but no effect.
sstrell
You are using bit_cnt as an index for dat_in, but the value of bit_cnt can become greater than 7 (the range you set for dat_in) because you are incrementing it up to 10 at max.  So without compiling it myself, something is getting optimized or latched because of this.  You probably are seeing warnings in the messages window about this.  Can you post those warnings?
ShengN_Intel
By adding output dat_in,
in the code, you would able to see the reg[7:0] bit and reg[7:0] dat_in check the image below:
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
VitPri
Hi Sheng,
Your advice worked very good. It fix problem. Now I can see  everything like it was declared. Thanks a lot.
But just for understanding - why regs was converted to combinational?
ShengN_Intel
Those registers are not converted to combinational, but being optimized away because don't have an output so didn't show up.
Sheng
ShengN_Intel
Let me know if you have any further concern or update on this thread.
Sheng
VitPri
